Re: Saginaw hitch on H
Posted by glennster on April 21, 2010 at 13:36:30 from (76.217.96.153):
In Reply to: Saginaw hitch on H posted by RMOMN on April 21, 2010 at 09:17:16:
you shouldnt need to replace the bolts, but you will need some big wrenches or a 3/4 drive socket set to remove them. the hitch mounts to the existing bolts and all you do is remove the vertical angle irons on either side of the hitch and the saginaw bolts right up. its heavy, and you will prolly need a couple floor jacks and blocks to hold it up there. here a pic of the saginaw on my m. spray the bolts up good with penetrating oil before trying to remove them
third party image
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
