Re: H Hydrolics Info
Posted by mkirsch on May 04, 2010 at 13:37:02 from (64.80.108.56):
In Reply to: H Hydrolics Info posted by ewalker on May 04, 2010 at 11:39:30:
ewalker said: (quoted from post at 11:39:30 05/04/10) Good point about a 2way being made a 1 way, so I could plumb so the 3 pt still work and use some other impliment?
The only way to make that work is to add two separate valves, or a two-spool valve, to the system.
Your H's hydraulic is only capable of controlling one function at a time; even if you add the typical two-way valve to the system you will still have to disconnect the 3pt to run the disk.
If you add a two-spool valve to the system in place of the valve pictured in the diagram, you can control two functions.
You could add a single two-way valve, and a single one-way valve ganged together, or you can get a two-spool valve that has a one-way, and a two-way together in one package.
But, your 3pt cylinders probably are just two-way cylinders with vents in the down side of the cylinder. You can convert them to tow-way very easily by adding hoses. This will allow you to buy a two-spool two-way valve setup for maximum versatility.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
