Re: Farmall Sickle Bar Mower Help
Posted by Al L. in Wisc. on July 10, 2010 at 04:54:01 from (216.226.92.151):
In Reply to: Farmall Sickle Bar Mower Help posted by fs6613 on July 10, 2010 at 03:36:27:
fs6613; something must be wrong w/you. Operate is manually?? Are you an old fert that has a rotary knob to turn the tv channel; maybe you grind beans for coffee!! Hats off to you for this project. Maybe you have already tried it, otherwise I could suggest searching the great archives. Subject or author search (I can suggest the late Hugh MacKay, as he had a few offset Farmalls; although I believe he had belly mowers) worth a try. Good luck w/your project. My grandpa, then passed down to my late dad, had an A. Wish I had paid more attention to old stories he told about his life on the farm/neighbors, etc. Folks lots smarter than me will probably chime in...other old ferts that may recall just what you are looking to do. Hhhmmm, maybe time next week to get my flat top re-cut and some of the gray removed.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
