Re: Stuck 460 diesel engine
Posted by stuart on August 01, 2010 at 20:03:32 from (64.198.86.189):
In Reply to: Stuck 460 diesel engine posted by tntleake on August 01, 2010 at 15:09:00:
Dont do something stupid like using the starter if it is stuck bad. Pull the head and soak the piston, then try to turn the engine backwards, this way you are not trying to push the piston rings past all that rust. Then hone the cylinder and your good to go, that is unless it is really bad and you need a new sleeve.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
