Re: Hydraulic Filter
Posted by rusticredacres on February 14, 2011 at 20:25:55 from (209.43.82.118):
In Reply to: Hydraulic Filter posted by farmall706 on February 14, 2011 at 20:17:41:
You will loose about 1 gallon or less. set a bucket under the cover and catch it when you remove cover.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
