Re: farmall H not firing
Posted by Dave J on September 03, 2000 at 03:29:50 from (202.72.154.88):
In Reply to: farmall H not firing posted by jdhump on September 01, 2000 at 22:03:53:
I have only just started rebulding this tractors and so far i have only worked on super A i had a simmilar problem with an A it was the point Gap not set correct it gave exactly the same symptoms
your getting (even with bad point gap i would still see a good spark when i tested it) but it would'nt start hope that helps
Post A Followup
: Re: Re: farmall H not firing
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
