Re: Is it ecessary to shut off fuel on diesel tank?
Posted by Bob M on May 01, 2012 at 19:15:07 from (74.67.189.51):
In Reply to: Is it ecessary to shut off fuel on diesel tank? posted by BerryG on May 01, 2012 at 15:38:04:
I believe the tank shutoff is provided simply to prevent fuel loss while changing the primary fuel filter.
As long as the fuel system is in good shape (ie. no leaks) there's no reason to close the shutoff when the tractor is shut down.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
