Re: IH574 Diesel
Posted by Janicholson on September 04, 2012 at 18:50:58 from (96.24.99.126):
In Reply to: IH574 Diesel posted by jcip on September 04, 2012 at 18:36:20:
jimB2 is correct. It is water condensation and a mix of soot and volatiles. It will dry in a while to a black stain. It is from cols engine parts condensing water and carbon. Work it on a Mill, or pull a plow, or bush hog as fast as the engine will take it without bogging. Then it will be OK till you idle it around more then it will slobber more. It is not a gas engine, and it needs to work to run well. Jim
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
