Re: Delco Distributor
Posted by pete 23 on December 06, 2012 at 19:48:36 from (74.32.238.2):
In Reply to: Delco Distributor posted by P.C. on December 06, 2012 at 09:13:30:
Are you getting part number 1960833 cap. There are two distributors with screw down caps for that engine. Another distributor has clips. One with screws is for points and other is for electronic. The 544 catalog does not show engine parts so one has to go to the C-200 engine manual and that might be the problem. Wrong cap.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
