Re: power steering not working with addition of front loader
Posted by IH fan on December 20, 2012 at 10:25:21 from (108.246.53.146):
In Reply to: power steering not working with addition of front loader posted by maurice dodson on December 20, 2012 at 09:22:41:
If you have the loader working off the valves built into the tractor dash, it should work because there is a built in priority flow divider (this assuming everything is as it came from the factory). If you are using valves that came with the loader, you are no doubt by-passing the priority valve and the loader "robs" the flow ahead of the pfdv. You don't say how it's plumbed. If in fact you are using the tractor valves, your torque generator may be weak, but you should also notice it's not as strong as it once was, even without the loader. On an older tractor, there could also be enough internal leakage in the system that it would not work well at idle, but should work reved up an it has more flow.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
