Re: engine oil in gas farmall 460
Posted by RPM1941 on April 02, 2013 at 18:42:44 from (173.23.76.185):
In Reply to: engine oil in gas farmall 460 posted by Matt (NEIA) on April 02, 2013 at 15:04:28:
I would advise IH (now CNH) low ash oil, it is made for these engines specifically to address the spark plug fouling from ash deposits in the oil & gasoline, It was originally the same spec as LP engines oil, it would foul plugs in heavy work very easily. 460/560 was the main tractor in early 60s from IH in gas engines, the farmers at that time didn't like diesels, smell & hard start in winter + noisy. I worked at IH/CNH dealer for 47 years in Iowa. Wish I had a penny for every 5 gal of Hytran & engine oil I handled.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
