Re: H leaking water near cam gear cover
Posted by John M on September 20, 2013 at 07:14:22 from (68.115.194.228):
In Reply to: H leaking water near cam gear cover posted by Pete76NY on September 20, 2013 at 06:39:40:
Probably water pump, packing nut needs tightened or packing replaced. Could also be a loose hose clamp near there.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
