Posted by mkirsch on April 18, 2014 at 10:34:48 from (65.199.189.6):
In Reply to: Drawbar pivot pin posted by BigTone on April 18, 2014 at 08:11:34:
Keep in mind, it's pretty much the only thing keeping whatever is behind your tractor, behind your tractor, out of your lap, and out of anyone else's lap. You generally want to use the "right" part when it comes to something like that, and $20 is a small price in comparison.
I don't think a bolt will fit right in the hole. Either the hole is an odd size, or even if it is the same NOMINAL size as a bolt, the bolt will be a few thousandths undersize and loose in the hole. Loose is bad. Loose gets to chucking and wallowing.
You want a good tight fit in the drawbar casting and belly of the tractor.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
