Re: Drawbar pivot pin
Posted by Nebraska Kirk on April 18, 2014 at 11:00:16 from (207.91.4.159):
In Reply to: Drawbar pivot pin posted by BigTone on April 18, 2014 at 08:11:34:
Get a piece of plain mild steel round stock. I am going by memory here, but I think it is 1-1/4" in diameter. Don't use a bolt, you would have to cut off the threads and the head, plus a bolt that size will probably cost you $20 :lol:
You can also get precision round stock that has a more precise diameter. Expect to pay $5-$10 at the steel yard.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
