Re: Wide front for 300 Farmall
Posted by mkirsch on April 24, 2014 at 05:28:52 from (65.199.189.6):
In Reply to: Wide front for 300 Farmall posted by bigboreG on April 14, 2014 at 18:25:47:
460/560 front ends will NOT bolt up to the 300 front bolster.
The 300 is a "narrow frame" tractor same as an H.
Both the 460 and 560 are "wide frame" tractors up front, same as an M.
Really, there is no modern wide front that will bolt to a 300. When IH went to the 460, they used "bump-out" frame rails to accommodate the big 6-cylinder engine block, making the front of the tractor the same width as the 560.
The 350 was the last of the fully narrow frame tractors, and the factory IH wide front for those had 3-spoke cast wheel hubs.
If you want 6-bolt hubs, you will need to find a Schwartz wide front as Allan suggests.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
