Re: Crank Shaft Bearing
Posted by rustred on April 26, 2014 at 17:33:15 from (74.214.152.80):
In Reply to: Crank Shaft Bearing posted by Dave8N in Pa on April 26, 2014 at 09:53:52:
you should specify what you are working on or referring to before the confusion get too big.
brgs.- yes
seals- usually no, unless you have a rope seal.
if you are referring to an old 390 ford then the answers are yes to both.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
