Re: SWDR9 water jacket cover plate
Posted by sflem849 on May 09, 2014 at 11:48:28 from (65.31.118.19):
In Reply to: SWDR9 water jacket cover plate posted by RedJohn2 on May 05, 2014 at 19:37:30:
I have some that could give you a start. They are stamped and the deflector things are rotted/rotting off but there is tin riveted to them to rebuild them a little. They are nowhere near as good as good ones, but better than nothing.
I have one more parts motor that may have good ones. But that is going to be a while. First I have to build an engine stand and then get time to take things apart.
Centex Farmall may have some used ones. He just came into a flock of 9 series machines.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
