Re: 450 pop in exhaust
Posted by matt bock on August 20, 2014 at 11:58:03 from (66.232.184.176):
In Reply to: 450 pop in exhaust posted by chris450 on August 18, 2014 at 19:01:38:
id spray carb cleaner around the intake gaskets and carb to see if u have a vacuum leak that will make them pop at idle
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
