potential Farmall M rebuild questions
Posted by hoosierhog on February 05, 2015 at 15:36:35 from (69.128.173.247):
looking at a few Ms for a project. Id like to keep it around when I'm done and use it a bit. raking and tending hay. But i really like it if i could use it to pull a disk or plow. i have a 3-14 pull type and a 10ish foot ih disc. both I want 45 hp on minimum. Just curious as to how much hp I would gain by boring out to 4 or 4 1/8 and sleeving the cylinders. I don't have an unlimited budget but keeping the M would be a bit more justified if it had a few more ponies.
how much hp can i add without tearing stuff up and how do you recommend doing it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
