Re: potential Farmall M rebuild questions
Posted by fastfarmall on February 05, 2015 at 16:00:59 from (24.92.172.177):
In Reply to: potential Farmall M rebuild questions posted by hoosierhog on February 05, 2015 at 15:36:35:
Every time you grind the valves, you lose a little bit of compression,so if u would put in new 4 in Fire Craters, or their equal, and a new set of valves, and true the head up a sniff you will surely have enough power to pull the equipment you mentioned. I pull a 13.5 Ft ,IH no 47 disk, with new blades, with a 12 big suitcase weight on the top, easy with my M.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
