Re: potential Farmall M rebuild questions
Posted by pete 23 on February 05, 2015 at 19:49:37 from (50.33.19.244):
In Reply to: potential Farmall M rebuild questions posted by hoosierhog on February 05, 2015 at 15:36:35:
An M's bore is 3 7/8 inch factory and a thick sleeve. Ninety percent or more have been overhauled with thin wall sleeves which give you a 4 inch bore. With a gasoline head and fire crater pistons you are looking at 50 horsepower. Flat head pistons right at 45.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
