Re: potential Farmall M rebuild questions
Posted by John M on February 06, 2015 at 03:37:04 from (209.213.30.16):
In Reply to: potential Farmall M rebuild questions posted by hoosierhog on February 05, 2015 at 15:36:35:
You cant use the 4 1/8 set without boring the block to accept the sleeves. Get a set of Firecraters or the high altitude pistons and sleeve for an M, a 450 gas head and cam, and tweek the timing some, youll get more than what you want. I really don't know if the cam makes a difference or not, but we replaced the one in Dads M when we replaced the head, since the the old cam looked shot and the lifters were wore pretty bad. We also used the Super M carb, and had to move the choke rod, but that was easy. Also has a propane intake. It dynode at 64, but the engine has had a lot of field time on it before it was checked, like 9 or 10 years of work, so Im sure it would have been a tad higher when it was first rebuilt.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
