Broke It.
Posted by Fatamus on February 18, 2015 at 10:24:39 from (72.35.102.213):
Broke my first shear pin. I noticed the u-joint knuckle joints are of a type I've never seen. The u-joints look like common ones but I see no way of replacing the u-joints without cutting the welds to get the yokes apart.
Were these the cheep type of knuckle joints back then and you replaced the whole knuckle joint and not just the u-joint?
third party image
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
