Re: H won't run
Posted by The Red on January 14, 2001 at 01:56:14 from (12.75.197.21):
In Reply to: H won't run posted by Dead H on January 13, 2001 at 14:53:19:
On the high speed mixture screw, you will see a hex packing nut. I believe it takes a 1/2 inch box or open end wrench. Turn the packing nut clockwise while keeping a screwdriver on the screw so that it will not change your mixture setting. As you tighten that nut down, the packing should get tighter around the stem of the screw so it won't be loose.
Did the H come to life after opening up the fuel screw?
Post A Followup
: Re: Re: H won't run
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
