Posted by Larry B. 1486 on March 16, 2015 at 16:38:10 from (72.105.170.5):
Last year my 1466 was getting hard to start when leaving it sit for long periods of time, talking two to three months. The end of last Nov. I tried to start it and could not get it to fire. Been sitting all winter and today tried to start it again. Had to hook another tractor to it and pull it, batteries getting weak. We pulled it a mile down the road and back. Pulled it fast enough the tach. was reading 1200 rpm. and oil psi was up to 70lb. Could not even get any smoke out of it. None. Thinking fuel problem. Checked filters, bleed filters, fuel tank full, checked if the hose from filter to pump bad, fuel pouring out at the pump, will run on ether. It's getting fuel. Throttle linkage works correct also. Tried pumping it up with the plunger pump also. Any one have any ideas?? Injector pump problems???
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
