torque setting for WD45 head
dave in mn
08-30-2005 11:28:21
I would appreciate the info on what the torque setting is for the 1/2" head bolts and 3/8" studs coming out of the engine block. Thanks in advance
Dave
Texas Denny
08-30-2005 21:04:48
 Re: torque setting for WD45 head in reply to dave in mn, 08-30-2005 11:28:21
Do all center bolts first, then the next two in one direction then the next two in the other direction. Repeat until all tightened. On first pass, torque to 45# on 1/2" studs and 15# on 3/8 studs. Repeat whole procedure at 70# and 25# respectively. When engine is hot, re-torque all bolts. These torques are from the IT manual.
Dick L
08-30-2005 13:39:11
Here is a chart that will will work for all bolts. Head bolts are grade eight.
third party image
