Re: Farmall M
Nathan in Texas
03-04-2005 16:24:40
third party image
Here is the 3 point setup. It has the post hole digger attached right now.
Nathan in Texas
03-04-2005 16:25:38
 Re: Farmall M in reply to Nathan in Texas, 03-04-2005 16:24:40
third party image
Other side of the 3 point setup:
Nathan in Texas
03-04-2005 16:28:48
 Re: Farmall M in reply to Nathan in Texas, 03-04-2005 16:25:38
third party image
And the worst for last. Here is the pic of the oil leak. From what the guy told me it has always leaked here and it hasn't seemed to get any worse, but if you guys have any input on whether or not I should be worried about it I would appreciate any comments. Also it seems like there is a separate leak right at the bottom left where the parts come together in this pic.
farmallhal
03-05-2005 07:15:45
 Re: Farmall M in reply to Nathan in Texas, 03-04-2005 16:28:48
Nathan, I should have suggested to clean up that leak area with some spray Gunk or other oil and grease remover and some water under pressure. Then keep an eye on it and see what it appears to be and what is the source. You are gonna love your tractor and they are simple in design and easy to work on especially with this group on the forum. Have fun and be extra careful until you get the feel of the young lady.
williamf
03-05-2005 04:09:13
You're gonna love that tractor. Can tell just from the pictures that it's a good one.
Hal's right about the hydraulics, but it looks like it's leaking around the seal on the shaft of the belt pully, too. My H leaks there, and I swear that one year I'm going to get around to fixing it. Not hard to replace that seal, but it's not hard just to wipe it off when I want to make a good impression, either.
Enjoy
Wm
farmallhal
03-04-2005 20:00:10
Nathan, Looks like a very nice M for being as old as they are. Looks well taken care of and the grill really looks nice and straight. Maybe you don't have brush down in Texas to bend them up though. The oil leak looks like it could be around the belly pump hydraulic fill and vent cover. Usually, there is some felt or some breathable material in the top of the cap to keep it from squirting out when the reservior is filling. Make sure it won't fall down into the eeservior though - a washer which just fits in the cap under the vent material should work if the dip stick is missing. Also, it might be too full - It holds 6 quarts when full. You would probably be best to drain and refill the hydraulic pump as it might also have detergent oil in it which foams. The manual states to never fill when implements are raised or the reservoir would be overfilled when they are lowered. Also you should use a non-detergent oil (I use 30 wt. here in Missouri) or some folks say to use Hy-Tran which is thinner and is probably more prone to leaking. You can get an Owner's manual from this site or Binder Books if you don't already have one. Have fun and enjoy your M as they are sure sweet tractors.
Nathan in Texas
03-05-2005 09:04:55
 Re: Farmall M in reply to farmallhal, 03-04-2005 20:00:10
Which manuals should I get?
There are a few on ebay that are CD roms that I could print out whatever I needed for about $25 or so.
On Binderbooks they have the owners manual for $20 and a service manual for the engine for $8.
Then there are about 50 other manuals for specific parts that I don't think I would need.
Thanks again for all the input so far!
Nathan
farmallhal
03-05-2005 14:50:15
 Re: Farmall M in reply to Nathan in Texas, 03-05-2005 09:04:55
Nathan, I would certainly get an owners manual, the service manual and a TC-28F (I think is the correct no.) Parts Catalog. The parts catalog is really good in obtaining the part numbers of parts you need before going into a dealersdhip or contacting a parts supplier online and it also shows exploded views and assembly sequence of parts into a major assembled component. It will also identify the parts by their proper name for discussion and communication purposes. If you plan on doing any service work yourself and you have some basic mechanical skills also obtain an I & T Service IH shop manual. The number of the I & T manual for an M is IH-8. The I & T manuals can be purchased at serveral locations like a Farm and Home, tractor dealerships, etc. but don't think Binder Books sell them. I got my I & T manual off EBay for around $10 and I think they sell for around $25 or maybe more at the Farm and Home type stores. Let's hope you won't need the engine related manuals quite yet and I believe they are for serious stuff like rebuilds and major internal repairs. Hope this helps and I have left my email open if you want to chat off forum. How did the M run today - I'm sure you did a little trip around the place to get the feel of the lady. Hal
HarleyMac
03-05-2005 16:20:26
 Re: Farmall M in reply to farmallhal, 03-05-2005 14:50:15
The leak you showed is the seal on the papper pully PTO shaft. it is an esay fix. take out the three bolts and pull out the gear ass'y and replace the leather seal with a new rubber seal from NAPA parts store. and the hydrlic liftalls seem to fid leaks no matter what you do.
Nathan in Texas
03-05-2005 15:58:34
She ran great!! :-)
Not many jobs you do that you get done and find yourself singing to yourself!
I got the blade that came with the tractor today and it's a nice 7 footer! (He just said he had a blade but couldn't remember how big it was). Wasn't near as much work to switch out the post hole digger and hook up the blade as I thought it would be. Did it by myself in about 5 minutes no problem.
It has been sprinkling most of the day so that seemed like perfect weather to be out on a tractor blading a road! She can really scoop up the dirt! Worked awesome! Spent about 2 hours smoothing it out and was pretty happy with the end result.
I think I will just order the CD off of ebay. What weight engine oil does it use? 30 weight non detergent? I need to add a quart and would like to use it a bit more before the service manual gets here!
Here is a link to the CD I am looking at. It says it includes the owner's manual, service manual and the parts manual for $25. I think it will really be a good thing to have because there are a few broken guages and a few switches that the guy I bought it from didn't even know what they were for.
Thanks again for all the help.
Nathan
farmallhal
03-05-2005 16:27:53
 Re: Farmall M in reply to Nathan in Texas, 03-05-2005 15:58:34
Nathan, CD's certainly have their place and are just perfect for some people. Just get what you are comfortable with but you do need something. The Servicemans Guide is not a service manual but is a publication for new tractor dealer preparation for delivery - I think they contain about 20 pages. I never got one as the person at Binder Books told me every thing was covered in more detail in the Service Manual. I purchased a printed service manual and used it right away doing a governor adjustment. It gave step by step directions. Might be a good one to have in paper format to use next to the tractor when something needs done. About the oil, you should probably use 30 wt. detergent being in a warmer climate year around. The manuals will say non-detergent but that was before detergent oils came into existance as you are talking about a 1939 first production unit. Everyone I know uses detergent oils in these letter series tractors and some folks really like the multi-grades like 15W-40. I just kept using the straight detergent 30 wt. in mine since that is what had been used by the previous owner since a complete rebuild and restoration. In case you don't know, you check the oil level by the two petcocks on the side of the oil pan. The owners manuals says to open the bottom one and drain down to that level daily. Tighten it up and fill until oil comes out of the top one. Should be about a quart between the two levels. Don't overfill the tractor and I would think a quart above the lowest petcock is enough. Again, this oil check and daily fill thing is based on 1939 oil sources and prices - probably came in 5 gallon cans and was penneys to the quart. You put oil in the tractor through the top of the right side front engine cover in front of the distributor. There is a large cap (about 2" in diameter) with a ridge down the middle and a bolt through the center which is removed to pour in the oil. Again, hope this helps and enjoy the pretty lady. Hal
