1. The model 801 had a lower piece of sheet metal called the Lower Panel Assembly, PN 310032. 2.Working up, you will have grill that looks like a large egg crate. 3. Behind the grill is a screen that has a waffle effect to it. The screen and grill are attached to the side panel assemblies with thumb screws at the top and bolts at the bottom. 4. Above this grill is the hood panel top assembly that contains the 801 emblem. 5. The hood panel top assembly is attached to the hood Right Hand and the hood Left Hand. They are not interchangeable. 6. On each side of the hood panels are the Hood Gusset Assemblies, LH and RH. 6. Between the two hood panel assemblies you will find the Hood Top Center Panel. This is also called the gas tank trap door. When asking for this part be sure to state Diesel or gas. The lower panel assembly is being manufactured as an after market part. I was able to get one from Tanty Tractor Salvage in California for $100.00. I see them advertised in magazines for $195.00. To my knowledge the gusset assembly and the rear fenders are the only other sheet metal parts being manufactured as after market parts for the 801. I could be wrong in this. I was able to pick up sheet metal parts for my 801 at different tractor salvave yards. These parts are not cheap. I have a few sheet metal parts left over from my project. I may have what you want. Let me know.
