1957 621 or 641
winkvalve
09-12-2006 17:18:28
I bought this a couple months ago with a finish mower. I bought it to cut my field, (ok, mostly to have an old tractor) and I'd like to restore it. It's stamped 621, but has a pto and 3 point like a 641. the serial number makes it a 1957. I'm trying to find out what colors it should be and I need an axle pivot pin and bushing. I haven't been able to find the bushing just the pin. I'd appreciate any help I can get.
Winkvalve
09-13-2006 16:08:19
 Re: 1957 621 or 641 in reply to winkvalve, 09-12-2006 17:18:28
thanks guys, I noticed the radius rods were bent and never really looked at any others to see if it was normal. Does just being a 601 series make it a workmaster? I thought that was something extra.
Jim.UT
09-12-2006 20:17:23
Whether it's a 641 or 621 it should be almost all red except for the fenders, grille and wheels which should be gray.
Here's a sample:
third party image
I borrowed this photo from the photo gallery on this site. Also, it looks like your tractor has 8N or NAA fenders. The fenders in the photo above are the correct ones for a 601 Workmaster series.
GlenIdaho
09-12-2006 18:31:51
Winkvalve; regarding the front axle pivot pin, if it is a 1957 it is probably the threaded type. NH carries them and this web site has them too. The diameter is 1.75 O.D. and 4.5 inches in length. The tractor looks like it has a general purpose front axle. There are part numbers on the axle halfs and center axle. If you can find them, have your NH parts man look them up and confirm what axle you have. He can then tell you the pivot pin size and order you one.
Your photo indicates the radius arm(s) is/are bent and they need to be straightened. With a bad pivot pin and bent radus arms the axle may rotate upward and force the radiator shroud into the fan. You can straighten them your self relatively easily. Hope this helps.
winkvalve
09-12-2006 17:54:19
I put a picture with this but I guess I did something wrong, hopefully it works here
old
09-12-2006 19:33:21
 Re: 1957 621 or 641 in reply to winkvalve, 09-12-2006 17:54:19
Glen is right you have a bent radious rod. The color is also wrong, instead of blue it should be red in that area
old
09-12-2006 17:49:37
What you probably have is an 821 front end and an 841 rear end. Either way it would be red and gray
