Order Ford 801 Parts Online
Ford 801 Power Master Transmission question
Fitz
09-19-2007 14:50:56
I need to change the transmission fluid in my 1961 801 Power Master. 5 speed transmission.
Where do I drain transmission fluid?
Where do I add new fluid and how much?
Where do I check fluid level.
Any suggestions on type and oil weight of fluid I should use.
I live in South hot summers mild winters.
Thanks
Jim.UT
09-19-2007 15:03:57
 Re: Ford 801 Power Master Transmission question in reply to Fitz, 09-19-2007 14:50:56
You need an owner's manual. Until you get one, here are the three pages you need now.
third party image
third party image
third party image
The drain is item 24. The fill port is item 8.
