Order Ford 5000 Parts Online
65 ford 5000 turbo
norsky 63
12-11-2007 18:13:17
I'm fixin up a ford 5000. I looked up the # and its a 65 but it has a turbo. would this be original? how many hp? thanks i'll try post a pic.
RodInNS
12-11-2007 19:58:56
 Re: 65 ford 5000 turbo in reply to norsky 63, 12-11-2007 18:13:17
I'd hazard a guess that you have an M&W add on turbo. It's certainly not an OEM setup. The 5000 was never turbocharged.
What's it make?.... That's a loaded question. How much does it smoke? A whisper? A good blow, or does it look like a Mack on it's last revolution?
It could realistically make anywhere from the stock 60 HP all the way up to probably 115 HP depending on how wild they went on the pump. A number often kicked around on here regarding the M&W kits was about 90 on the PTO... That's probably about the point where harm would start on that engine, and perhaps a bit beyond that point on a 233... The later 268's were good for probably 100-105 without much harm, and the 256 somewhere in between.
Rod
Old Ford Mechanic
12-11-2007 19:51:28
Its an aftermarket M&W setup.Increased of about 10-15% in power.Good proven setup.Does have a pyrometer installed? If not you need one.
Ken L.
12-11-2007 19:00:27
No, a turbo would not be stock on the 5000. Notice the extra M&W oil filter?
JK-NY
12-11-2007 18:59:51
The 5000 was not turbocharged originally. Yours could be either a newer turbocharged engine (from a 7000,7600 etc.)or an aftermarket turbo and manifold. Originally the first 5000 diesels with 233 ci engine were about 55 pto hp.Hard to guess at your tractors hp without knowing more details.
norsky 63
12-11-2007 19:46:14
 Re: 65 ford 5000 turbo in reply to JK-NY, 12-11-2007 18:59:51
would it help to find a # on engine? If so where would that # be Thanks
norsky 63
12-11-2007 18:35:28
third party image
pic.
norsky 63
12-11-2007 18:37:17
 Re: 65 ford 5000 turbo in reply to norsky 63, 12-11-2007 18:35:28
third party image
another pic.
sotxbill
12-12-2007 16:12:43
 Re: 65 ford 5000 turbo in reply to norsky 63, 12-11-2007 18:37:17
yep.. its an m&w turbo... i still have some filters left in the shop for them... figure about 20% hp increase.. but also figure faster ring wear... turbo tractors are shipped with high crome top rings to handle the high temps.. non turbo tractors did no.. so the ring wear is a bit higher.. these were really popular where a aftermarket cab and a/c were added along with the turbo..its a rayco turbo on a m&w manifold... iirc.... sweet.... Bill
