Good lord! I'd give my eye teeth for that sheller..except I don't have any! I don't know what model it is, but I restored the simpler version of it, last winter. The son in law and me went to a farm sale and he found 2 derelicts...one was a New idea and the other the McCormick. Both looked like 9 miles of bad road! He bought them for both for about $25 and loaded them on the truck. Knowing I had already restored a Deere 1-B and and old Hocking Valley...of course, I got the honors of doing these new additions! Yours looks pretty good just as it sits, unless the bearings are shot. I would sand blast it and paint it farmall red, replace the chaff blower belt and the cob chute conveyor chain and call it done. If the bearings are bad...they are just iron castings...I'd get some ball bearing pillow block bearings to replace them with...that is what I did on two of my shellers. They run smoother than they ever did originally and you never have to worry about oiling them. If it comes to that, you're in for a lot of work because even back when they made these shellers, they used the cheapest and fastest way to assemble them....they riveted the bodies together. You'll have to cut the rivets out...I used a die grinder. I put it back together with bolts and nuts. If you have to use pillow block bearings, there is a guy on ebay who sells them right and has any kind/size you could ever need. They are Korean made but of very good quality..certainly good enough for a corn sheller. But, you will have to use wider angle iron supports where the bearings sit..than what was originally used. take pictures of everything as you tear it down..so you can remember exactly where everything goes...some of the tin baffles inside can be installed upside down....don't ask me how I know..hehe! Don't throw anything away..you may need it for patterns. I motorized all of my shellers and yours is set up for a hit&miss engine...which will cost you out the ying-yang to get...unless of course grandpa's is still amongst your goodies. You could substitute a new type gas engine I guess, but they don't have the low rpm torque like the old engines did....and you don't need lots of rpms! My email is open, send me a note and your email address and I will send you photos of my efforts and where I got the bearings. Whatever you do, get that sheller in out of the weather! That's a nice one.
