Lou, fluid steel is fine for modern, nonsteel loads. I have a '97 Winchester. I have shot a lot of ducks with it before steel was mandated. I shoot it now for pheasants/quail etc. though not often because other guns work better for me. The veined appearance is probably "fake" damascus that was used to be decorative and appear as damascus because that was once considered superior. I've never seen this applied to a 97 but that may indicate that you have a high grade model. In any event, it is "safe" to shoot with any reasonable lead load. The chokes will not stand up to much steel shot so avoid that. There is one or two caveats about this particular gun that you should be aware of. First, it will slam fire. That is, if you pump the action while holding the trigger down it will fire. This could be a safety issue for some, but I do not find it a problem - I just don't do that. The second is that the hammer can slip out from under the thumb of the most careful shooters as you cock it back from half cock to full, or as you set it down to "safety" half cock. I have done this exactly twice while hunting. The first time, it shot blue sky. The second time, it killed the quail I wanted, but before I got the gun to my shoulder. Muzzle control with this beast is a must. A friend with reason to know told me once that this gun had accidentally killed more people than any other, due to this very feature. Not sure I believe this, but I tend to use this gun only when hunting alone for this reason. Brent
