[I'm also sending this to your email address, as you requested, but I'd prefer to discuss this here where we can learn from others, and preserve the conversation to help future searchers.]My NAA hydraulic problems sound quite different from yours -- I've read your postings over the past few days but had little to add -- but maybe it'll help to discuss our separate problems. (I'm planning to try and fix mine this winter.) Here's a brief summary of my problem: My lift drifts down when the power is off, and it "hiccups" continually (but works otherwise, and holds quite a bit of weight). By "hiccup" I mean it drops slightly (maybe an inch or an inch and a half when observed at the end of the bottom links) and then quickly corrects itself. The heavier the implement, (and to some extent, the higher the engine RPMs,) the more frequently these corrections happen. This doesn't make it unusable, but it's irritating, especially with a heavy implement, to be bouncing like that all the time, and I suspect it puts stress on the system that can't be good for the long run. I've read the I&T manual's sections about hydraulic problems and most of ZANE's (and others') postings on the subject, and I suspect the master cylinder is leaking -- at least that's what I'll look for first. Other difference: I have a piston pump rather than a vane pump, and I have a single-action hydraulic remote that runs to the front of the tractor -- currently unused, probably used for a front-end loader or something similar in the past. (I don't know whether that will complicate the process of disassembling and repairing mine -- anyone know?) (I'm seriously considering getting one of ZANE's repair documents, based on the praise I've read from other posters, but will wait until I'm ready to start working on this.) Do you know anything more than you've already posted about *your* problem yet?
