Typically, polarizing refers to jumpering a shot of battery voltage into a DC generator before startup of the engine to restore residual magnetism, of the correct polarity, into the generator field polepieces so that, upon engine startup the generator will begin to charge with the correct polarity to match that of the battery. If the tractor has been run recently, and the generator was working, AND you are sure the battery is charged correctly, AND you have installed the battery with the same ground polarity as before, you do NOT need to polarize the generator. However, if the tractor has sat unused for a long time, or if the generator has been apart, or if you are not sure of how the battery was connected before, and you are now reinstalling the battery with the CORRECT POLARITY, you need to polarize the generator. You don't mention the exact machine you're working with, so I have given a pretty general answer. Also, if it is a newer machine, or has been updated to an alternator, the battery MUST be connected with the polarity the alternator was designed for. (USUALLY NEGATIVE GROUND, BUT THERE ARE EXCEPTIONS.) And you NEVER attempt to polarize an alternator.
