Order Ford 8N Parts Online
8n headlight wiring
Marks8n
10-20-2006 19:53:05
I will be adding headlights a work light and a tail light, I will be using a 6v positive ground system. The light switch has 2 lugs to attach wires, I assume a negetive wire goes to one lug in on the switch and then 2 wires come out on the other lug 1 to the left head light and then splits to the right headlight, then wire 2 goes to the tail light and then splits to go to the work light that is switched internaly.
Does this make since.
In theroy this should work I think?? since this is a positive ground system????? Am I wrong?????
Anyone have diagrams or know if any one makes a harness for this application ready made. I have bought a new wiring harness for the engine and looks like light circuts are not included.
Russ SoCal
10-21-2006 07:48:21
 Re: 8n headlight wiring in reply to Marks8n, 10-20-2006 19:53:05
Marks8N,
Yes you are correct. Here's a picture of the routing.
Russ
third party image
Marks8N
10-21-2006 08:43:12
 Re: 8n headlight wiring in reply to Russ SoCal, 10-21-2006 07:48:21
Thanks Russ and everyone you guys rock, I assumed I was going in the right direction but wanted to be for sure.
Russ SoCal
10-21-2006 07:52:49
 A little bigger? in reply to Russ SoCal, 10-21-2006 07:48:21
third party image
BillM (OH)
10-20-2006 20:31:13
Wiring harness does not include light wiring. Hook the lights up in parallel (as opposed to series) - light switch to same side of all - ground to other side of all - otherwise the last 2 won't give out much light, due to the resistance of the ones upstream.
old
10-20-2006 20:21:00
Weather its + ground or- ground it doesn't matter. Either type of ground is wired the same for lights, starter, and a few other things. The only place it matters is the coil and weather is has an alternator . Most genny can/do work either way also. There are a few gennys that don't but for what your doing it doesn't matter.
