FORD 4500 BACKHOE 1971 MODEL
NORM IN N.H.
07-28-2007 11:03:39
I'M REBUILDING A 201 CID ENGINE,AND NEED TO KNOW ABOUT SOME KIND OF FUEL INJECTED STARTING SYSTEM WITH A THREADED FITTING THAT GOES INTO THE INTAKE MANIFOLD. UNFORTUNATELY,MINE IS INCOMPLETE. I WOULD BE GRATEFUL IF SOMEONE COULD EXPLAIN HOW THIS SYSTEM WORKS, OR IS THERE A SPECIFIC MANUAL DETAILING IT'S FUNCTION?
murn ga
07-28-2007 11:52:27
 Re: FORD 4500 BACKHOE 1971 MODEL in reply to NORM IN N.H., 07-28-2007 11:03:39
third party image
The 4500 cold start is elec and fuel. When the key switch is in the correct position,the thermostat plug heats a coil and at the same time opens a ball check valve to allow fuel to dribble into the intake manifold from the resvoir pot mounted to the left of the voltage regulator.This fuel ingnites and aids in starting a cold diesel.This break down might help,it will be the same as 4000 65 up.
norm in n.h.
07-28-2007 13:29:41
 Re: FORD 4500 BACKHOE 1971 MODEL in reply to murn ga, 07-28-2007 11:52:27
HI MURN! THANKS FOR THE QUICK RESPONSE- UNFORTUNATELY EVEN W/EXPANDING THE SCHEMATIC DIAGRAM, I STILL CANNOT READ IT. IS THERE ANYWAY YOU COULD SEND A LARGER SCHEMATIC?
murn ga
07-28-2007 13:48:12
 Re: FORD 4500 BACKHOE 1971 MODEL in reply to norm in n.h., 07-28-2007 13:29:41
sure,e-mail me.
