Posted by Pete in PA on June 14, 2009 at 18:31:48 from (173.67.150.195):
Hey All,
OK so I tried a few things with my 140 to see if it"s the clutch or transmission, as suggested here (thanks Haas, Hugh & Janicholson), but still no dice. I found that one of the clutch levers had come half off and was twisted, so after spending saturday doing surgery on it, finally got that lever straight and repinned. (What a bear without taking the clutch/tractor apart)
Janicholson suggested I play w/the PTO with it in gear and not, so I did that - in gear, it just spins and the tractor doesn"t move, so I am assuming it"s either the clutch not dis-engaging (would like to lube it anyway, but can"t find the grease nipple inside the "dust cover" as per the manual - anybody got a map?), or as Hugh suggested, perhaps the transmission coupling has come off.
Hugh, have you or anyone else here attempted to get at the transmission coupling *without* splitting the tractor? Is this possible? How time consuming would you say it is to get at it?
Thanks in advance for any stories about similar problems.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
