I assume you put the PTO control in gear to make sure that if it was running it would spin the PTO. If the PTO is able to spin when it is engaged and the trans is in gear, something is broken in the trans. If it spins when the gear shifter is in neutral, the coupling, clutch disk, or clutch shaft splines could be bad. You might be able to see the coupling where the clutch rod goes in (maybe) JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
