I won't be able to get that open until this weekend. Other than just looking for corrosion, anything to look for on the bearings? I never been into the rear end of an M, can you really see the bearing on the input shaft or counter shaft?
Would that shaft itself be loose? I would assume that if that shaft is loose at all the bearing is shot.
I'll check as much as I can from that opening.
Thanks for the advice.
This post was edited by Marty from MN at 17:51:35 08/19/10.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
