Posted by jcwag on March 04, 2011 at 08:25:15 from (72.171.0.149):
have a farmall m that has the 6 volt ingnitor on it. had to put a 8 volt battery in it to get it to start. anyway that was 4-5 yrs ago and the battery died, so i have decided to switch it over to 12 volt and be done with it. i have a one wire alt that came on another tractor, and a 12 volt battery from one of my deeres that i replaced the batterys last fall, that i can use. questions are wiring the one wire, and will i need the ignitor or should i just put the points back in? also will i need a resistor or differant coil if i go to the 12 volt ignitor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
