Re: 12 Volt Conversion and ignitor
Posted by Janicholson on March 04, 2011 at 10:17:08 from (199.17.6.58):
In Reply to: 12 Volt Conversion and ignitor posted by jcwag on March 04, 2011 at 08:25:15:
With an ignitor, the best option is a higher energy coil. Follow the ignitor install directions. using the 6v igniter might work if you used the ballast resistor, but no guarantees on the method as It would be a risk to the ignitor.
The one wire hooks up to the load side of the amp meter (not the side hoked to the starter switch) Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
