1937 WC wont move need help
Allis chalmers
01-03-2008 09:31:26
My WC is together less clutch and engine. THe funny thing is it wont move now. I could be pushed through the shop alright here two weeks ago. Now the wheels are locked up. Any idea why its locked? I suspect it could be rust but if you have any ideas thanks in advance.
Allis chalmers 6
01-04-2008 09:42:14
 Re: 1937 WC wont move need help in reply to Allis chalmers 6, 01-03-2008 09:31:26
The breaks are free and it is in a temeprature controlled room. If that helps.
old
01-03-2008 12:44:33
Brake bands could have rusted or some one locked them. Ices as Eldon said, or as Phil has said.
Eldon (WA)
01-03-2008 11:21:22
How cold out is it? If there is any water in the bottom of the tranny or differential it will freeze and lock things up.
Phil Munson NY
01-03-2008 09:42:35
My guess is that the shifting forks are worn and someone has, not carefully enough, moved the gear shift lever and it may actually be in two gears simultaneously. HTH, best, Yeoman
