AC model CA slipping hand clutch
Jay
08-08-1998 09:59:27
I have a 1955 model CA. The hand clutch slips. Does any
one know of a source which sells new friction disks?
Howard Hutchens
08-14-1998 18:19:55
 Re: AC model CA slipping hand clutch in reply to Jay, 08-08-1998 09:59:27
: I have a 1955 model CA. The hand clutch slips. Does any
: one know of a source which sells new friction disks?
How bad is it slipping, there is an adjusting hub just below the the hand lever . I have had success adjusting the clutch with this in the past. Been awhile but believe turning
the hub clockwise tightens. Howard
jay
08-23-1998 05:46:40
 Re: Re: AC model CA slipping hand clutch in reply to Howard Hutchens, 08-14-1998 18:19:55
: : I have a 1955 model CA. The hand clutch slips. Does any
: : one know of a source which sells new friction disks?
: How bad is it slipping, there is an adjusting hub just below the
: the hand lever . I have had success adjusting
: the clutch with this in the past. Been awhile but believe turning
: the hub clockwise tightens. Howard
Thanks Howard for the info, as far as slipping, it is not too bad. I will attempt to adjust. Most of what is covered in manuals appears to be adjustments to make it release, nothing is mentioned about slipping.
jay
08-23-1998 05:42:09
Dan D.
08-09-1998 07:54:32
You can go right to the dealer and get a new lining kit which includes the two linings and rivets. E-mail me if you'd like the part number as I don't have it with me at the moment.
NEW YORK SAM
08-08-1998 16:13:26
CENTRAL TRACTOR IS A GOOD SOURCE
