WD shifting tower
alliswd45
01-30-2008 09:22:39
Anyone know where i could find the snap ring and retainer for the top of the shifting tower on a WD
Will Herring
01-31-2008 16:15:53
 Re: WD shifting tower in reply to alliswd45, 01-30-2008 09:22:39
I know I bought one for my tractor when I redid the shift tower after it got stuck in reverse and the shifter slipped out. I got my replacement one from AGCO. It was reasonable, and that was only... Three years ago.
MMB
01-31-2008 03:37:07
I wouth think you could get that at an AGCO dealer. I have bought several parts from the local AGCO dealer.. Some parts are high, others are about right...
JMS/.MN
01-30-2008 15:15:21
Where have you tried? AC/AGCO dealer? If no luck there- grind off a washer, to fit the space, drill out the bottom side with a large diameter drill- to sort of fit the angle needed to match the ball on the shifter. Snap ring is a generic thing- bring the tower to any reputable tractor dealer and the partsman should come up with something that fits and secures.
stu (ON)
01-31-2008 04:11:49
 Re: WD shifting tower in reply to alliswd45, 01-30-2008 16:32:44
Try www.sandylakeimp.com
They are AGCO & do mail order.
JMS/.MN
01-30-2008 16:46:09
Those suppliers are not likely to have small parts like you need. Agco dealer locater is at www.agcocorp.com, but my previous post should handle the problem. Just look for a ring thick enough to fill the space in the groove after you fit the washer.
