D-19 SERIAL # LOCATION
ACARKY
02-05-2008 20:42:39
NEED INFO ON LOCATION OF TRACTOR AND ENGINE SERIAL #s ON MY D-19D. MY OLD IT MANUAL STATES THAT THE TRACTOR # IS LOCATED ON THE LEFT FRONT OF THE TORQUE TUBE AND THE ENGINE # IS CENTER LEFT ON THE BLOCK. SO FAR HAVE HAD NO LUCK IN LOCATING. THANKS !!!
cadet trooper
02-09-2008 15:55:37
 Re: D-19 SERIAL # LOCATION in reply to ACARKY, 02-05-2008 20:42:39
My book says all D series tractors serial numbers were located on the front of the torque housing on the left side sitting on the tractor seat including the D-21 if that helps. You may have to take a wire wheel to expose it because someone may have loaded it up with paint over the years. You've gotta remember some of these tractors are close to 50 years old and may have several coats of paint.CT
Eldon (WA)
02-11-2008 07:18:14
 Re: D-19 SERIAL # LOCATION in reply to cadet trooper, 02-09-2008 15:55:37
I'd bet your book isn't an official AC book....and I think I would trust the operators manual before I would some data book or IT manual!
wilman
02-06-2008 07:36:42
Eldon is correct on where the D-19 serial number is. Back by the seat. The D-17 is on the left side by the clutch housing.
Wil
Jack a
02-07-2008 03:35:23
 Re: D-19 SERIAL # LOCATION in reply to wilman, 02-06-2008 07:36:42
My D19 has a number at both locations. Different numbers. One on torque tube makes it a 61 and one on rear housing makes it a 62. I have never seen another D19 with a number on the torque tube.
LeRoy DeLong
02-06-2008 05:44:32
I think you can find it also on the left side on the torque tube housing.
LeRoy DeLong
02-06-2008 05:47:22
 Re: D-19 SERIAL # LOCATION in reply to LeRoy DeLong, 02-06-2008 05:44:32
I goofed. Not on the D-19.
Eldon (WA)
02-05-2008 21:44:07
It is stamped in the rear end casting behind the seat on the right side. It will start with D19-
May be hydraulic hoses covering it up.
Joe(TX)
02-06-2008 05:00:35
 Re: D-19 SERIAL # LOCATION in reply to Eldon (WA), 02-05-2008 21:44:07
Are ypu sure about that Eldon?
I thought it was on the left side of the clutch housing
Eldon (WA)
02-06-2008 07:24:28
 Re: D-19 SERIAL # LOCATION in reply to Joe(TX), 02-06-2008 05:00:35
I guess the 3 that I have were all stamped by the hungover guy on Monday morning LOL....
Joe(TX)
02-07-2008 05:19:04
 Re: D-19 SERIAL # LOCATION in reply to Eldon (WA), 02-06-2008 07:24:28
You would know better than me then
John (MO)
02-06-2008 08:16:46
They were all stamped by that same guy, and in the same place. But later, in the tavern, he couldn't remember and told a few people they were stamped somewhere else, and now everyone wants to argue. But then when they actually find the number, back below the seat, they never seem to be heard from again.
