7030 electricial question
aFORDable
02-17-2008 19:30:46
Our recently purchased 7030 has 4 batteries that I am assuming are 6v. So I'm guessing it starts on 24v and swiitches back to 12v, is that correct? How can it be converted over to use 2 12v batteries and is that a good or bad idea? What about charging the batteries, do I us 12v or 6 v on the charger? Tell me how all this works and what is the best way to go for the best cranking. Any input will be greatly appreciated. Thanks.
cadet trooper
02-18-2008 09:53:20
 Re: 7030 electricial question in reply to aFORDable, 02-17-2008 19:30:46
You probably have the 4 battery start option which is 4 12 volt batteries hooked in paralell which was offered for the 426 especially for cold weather starting and should also have the heavier Neihoff alternator too. I don't know where you're located but if it's in a warmer climate you probably shouldn't need all four batteries two should be fine. Like someone else already stated it's 12 volt all the way no magic there.
Joe(TX)
02-18-2008 05:07:59
It normally uses 2 12v in parallel
glr62
02-17-2008 22:59:24
It is 12 volt all the way!! 12 volt starting and system. 2 12 volt batteries will work fine.
