oil for wd
AC newbie
03-18-2008 01:07:07
just bought a 1949 WD at auction. need to know what weight oil to use.
ACnewbie
03-20-2008 00:24:40
 Re: oil for wd in reply to AC newbie, 03-18-2008 01:07:07
thank you all
Bill in MA
03-20-2008 16:43:37
 Re: oil for wd in reply to ACnewbie, 03-20-2008 00:24:40
Check out the article on "What kind of oil I should use" in the Maintainance and Mechanical section under research and info. There are many opinions but this hits the nail on the head. Todays oils are 100 times better than they were even 25 years ago. This should put you on the right track.
tractormiallis
03-18-2008 19:38:34
Manual calls for 30 wt. 6 qts. Use a non detergent or else being it is an old engine it will burn oil if you use a detergent oil. Use fram 159 filter.
alliswd45
03-18-2008 15:35:03
I run 10W-30 in my WD
midlam
03-18-2008 06:33:07
I use 15w-40 diesel rated oil for all older gas engines. Most new oil has had the anti-wear agent ZDDP reduced.It was shorting the life of the oxygen sensor and cat converter. This additive is really needed to stop camshaft/lifter wear. Diesel rated oil still has enough ZDDP. I think the older SL rated gasoline oil was the last to have the higher level of ZDDP. SM,SG to newest does not have enough protection.
old
03-18-2008 06:00:17
30W is just fine but use a detergent type oil or you will sledge up the engine. Also be sure to use the correct oil filter or you will not have oil pressure WIX57011 I think is the correct number
ccrock
03-18-2008 03:21:51
I have a 52 wd and use non-detergent sae 40, and have been happy with it.
Brian Jasper co. Ia
03-23-2008 11:37:17
 Re: oil for wd in reply to ccrock, 03-18-2008 03:21:51
Old has it backwards. If it has lots of sludge buildup from using non detergent oil, continue with the ND oil. Detergent oil will loosen the sludge and circulate it through the system. Since a WD has a bypass filter system, the sludge, dirt, etc goes through the bearings. Not a good thing. Pull the side cover and see what it looks like. Clean, use detergent oil, full of sludge, use ND oil.
