STEERING ADJUSTMENT ON ALLIS B
amo
03-31-2008 17:06:43
How do you remove the loose play in the steering on a 1954 allis b? Thanks amo
Rex in Australia
04-01-2008 02:05:15
 Re: STEERING ADJUSTMENT ON ALLIS B in reply to amo, 03-31-2008 17:06:43
Hey Dick, I looked at the photos, nice job. Where did you get the peg or did you turn it up yourself? Would have to be a good hard steel?
Cheers,
Rex
Dick L
04-01-2008 07:35:15
 Re: STEERING ADJUSTMENT ON ALLIS B in reply to Rex in Australia, 04-01-2008 02:05:15
I turned it out of a hardened die pin cut off. It polished up fair. Next one I will leave extra metal and use the spin index under the surface grinder.
DickL
03-31-2008 19:24:53
Some times you can remove the starter and adjust the screw behind the starter to take up some slack. Chances are it has already been adjusted all the way in. You never know you might get lucky.
More times than not you will fint the pawl half or more gone.
third party image
davr101
04-02-2008 16:14:43
 Re: STEERING ADJUSTMENT ON ALLIS B in reply to DickL, 03-31-2008 19:24:53
I've heard of guys welding these up and then grinding them down to fit. If you need hardened steel, this probably won't work, will it? I also heard some of the pawls are removable, and replaceable. I need to do this to my 1950 B, but that will wait until next winter. It's parade time now!!
