Timing My Allis B?? How
arnettbros
04-04-2008 13:30:29
I had to replace the cap that goes over the points on my allis B, this tractor has a magneto. Their is a small gear behind that cap that meshes with another gear in front of the points-The question is how do I connect those two gears correctly to time the tractor? Right now my tractor is just back-firing when I try and start it. Many Thanks
chalmersbob
04-06-2008 19:44:40
 Re: Timing My Allis B?? How in reply to arnettbros, 04-04-2008 13:30:29
If you pull the front plug (#1) and place your thumb over the hole and crank the tractor until you feel air being pushed out of the cylinder. then check in the hole in the torque tube for the TDC mark. Once you have that, turn the rotor to the timing mark at the point #1 cylinder fires and install the cap, That will have it timed, Bob
Rod (NH)
04-04-2008 17:10:16
Try this, assuming your mag is the typical FMJ. Scroll to the end for a method to time the internal gears if the gear markings are missing.
Rod
steve(ill)
04-04-2008 15:08:09
read this- with photos
http://dueyschutter.freeservers.com/photo6.html
old
04-04-2008 14:46:13
Send me an e-mail and I'll send you a manual for that mag which will explain how to time it and all
Jerry Coulter
04-04-2008 14:42:02
On the little steel gear on the armature shaft, turn the bevelled tooth straight up. On the fiber gear in the cap, there should be a sticker showing A and C. Turn the C straight down and mesh them together. If no sticker, perhaps someone has made an indicator mark of some sort.
arnettbros
04-04-2008 14:46:27
 Re: Timing My Allis B?? How in reply to Jerry Coulter, 04-04-2008 14:42:02
I see the beveled gear, with it straight up does that mean number one piston is up? The sticker is gone from the other gear, unfortunately no marks on the gear itself. Any ideas? Can I point the rotor to number-one plug position on the cap? Thank-you!
Jerry Coulter
04-05-2008 08:43:18
 Re: Timing My Allis B?? How in reply to arnettbros, 04-04-2008 14:46:27
OK, I have a cap in my hand now. Turn the rotor so that it points straight down, having the flat of the rotor shaft on top toward the high tension rod hole. Now turn it around so that the rod hole is on top. You will see a gear tooth is on top pointing toward the rod hole. Now count COUNTER-clockwise, the top tooth being #0, to the notch between #4 & #5 teeth. Mark it. That is the C position which needs to hook over the bevelled armature gear tooth.
